TwinTurbo.NET: Nissan 300ZX forum - check the ohm's from the pins on the coil pack itself..
Paulym1111
on March 10, 2010 at 9:40 AM
Where do I check? At the coil or ECU? (n/m)
posted by BrianTT(Tpa,Fl)
on March 10, 2010 at 08:11 AM
you check the middle pin and either the left or right pin...dont remember which one, but one will give you a reading and the other will not so you cant really do it wrong.
I have found posts on how to check for bad injectors>
BrianTT(Tpa,Fl)
07:45:29 03/10/10
swap a coil pack from a working cylinder
Ahmed (Chicago)
08:02:17 03/10/10
coils should ohm around .7 (n/m)
Paulym1111
08:08:26 03/10/10
BrianTT(Tpa,Fl)
08:11:13 03/10/10
check the ohm's from the pins on the coil pack itself.. -
Paulym1111
09:40:01 03/10/10
Thanks for the info! (n/m)
BrianTT(Tpa,Fl)
09:58:55 03/10/10
I think it's better to actually run them and look for a
jzack
18:55:44 03/10/10
